{"product_id":"woodpeckers-auto-line-drill-guide-deluxe-kit","title":"Woodpeckers Auto-Line Drill Guide Deluxe Kit","description":"\u003cp\u003eThe Woodpeckers Auto-Line Drill Guide Deluxe Kit provides a portable solution for drilling accurately positioned, perfectly perpendicular holes in workpieces that are too large, awkward or inaccessible for a drill press. Combining a precision-guided drilling mechanism with a versatile fence and positioning system, it helps deliver accurate results whether you're working in the workshop or on-site. The Deluxe Kit adds extended fence capability for greater positioning flexibility and repeatable drilling operations.\u003c\/p\u003e\u003cp\u003eAt the heart of the system is a 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) chuck supported by sealed ball bearings and guided by precision steel columns. Teflon-lined guide sleeves keep the chuck travelling smoothly and square to the workpiece, while an adjustable depth stop allows repeatable drilling depths. The quick-release drive shaft is compatible with most corded and cordless drills.\u003c\/p\u003e\u003cp\u003eLaser-engraved centre lines on the base simplify hole positioning, while an integrated V-groove provides support for drilling round stock. The standard base opening accommodates drill bits up to 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter. By reversing the chuck carrier, holes up to 50.8mm (2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) can be drilled using appropriate cutters.\u003c\/p\u003e\u003cp\u003eCentring pins allow the guide to be accurately positioned on stock up to 79.4mm (3-1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide, while the adjustable fence system can be mounted on any side of the base for edge-referenced drilling. The Deluxe Kit includes additional guide rods for greater reach and positioning options when working on larger projects.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers, installers and woodworkers who need accurate drilling away from the drill press, the Auto-Line Drill Guide Deluxe Kit provides portable precision for large workpieces, installed components and workshop projects. Warning: Not suitable for use with impact drivers. Supplied with: Woodpeckers Auto-Line Drill Guide, adjustable fence, centring pins, depth stop, standard guide rods, extended guide rods and hex key.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036480192859,"sku":"114885","price":529.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114885_xl.jpg?v=1793618676","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-auto-line-drill-guide-deluxe-kit","provider":"Axminster Tools","version":"1.0","type":"link"}
