{"product_id":"woodpeckers-auto-line-drill-guide","title":"Woodpeckers Auto-Line Drill Guide","description":"\u003cp\u003eThe Woodpeckers Auto-Line Drill Guide provides a practical solution for drilling accurate, perpendicular holes when a drill press is unavailable or the workpiece is too large to fit on one. Combining a precision drill guide with an adjustable fence and centring system, it helps position holes accurately while keeping the drill bit square to the work surface.\u003c\/p\u003e\u003cp\u003eAt the heart of the system is a 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) keyed chuck mounted on sealed ball bearings and guided by two precision steel columns. Teflon-lined guides keep the chuck assembly travelling smoothly and perpendicular throughout the drilling operation. One column incorporates a return spring for controlled drilling, while the second features an adjustable depth stop for repeatable hole depths.\u003c\/p\u003e\u003cp\u003eThe base features laser-engraved centre lines for accurate hole positioning and a V-groove for drilling round stock. The standard opening accommodates drill bits up to 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter. By reversing the chuck carrier, holes up to 50.8mm (2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) can be drilled with suitable cutters. Included centring pins allow holes to be located precisely in the centre of stock up to 79.4mm (3-1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide.\u003c\/p\u003e\u003cp\u003eAn adjustable fence system provides edge referencing and can be mounted on any side of the base. The fence offers a standard capacity of 177.8mm (7\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), providing flexibility when working close to or away from an edge. The quick-release shaft allows the guide to be driven by most corded and cordless drills.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers who need accurate drilling away from the drill press, the Auto-Line Drill Guide offers portable precision for large workpieces, installed components and workshop projects. Supplied with: Woodpeckers Auto-Line Drill Guide, adjustable fence, centring pins, depth stop and hex key.\u003c\/p\u003e\u003cp\u003eN.B. Not suitable for use with impact drivers.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036479930715,"sku":"114859","price":359.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114859_xl.jpg?v=1793618596","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-auto-line-drill-guide","provider":"Axminster Tools","version":"1.0","type":"link"}
