{"product_id":"woodpeckers-autoangle-drill-guide-deluxe","title":"Woodpeckers Autoangle Drill Guide - Deluxe","description":"\u003cp\u003eThe Woodpeckers AutoAngle Drill Guide - Deluxe makes it easy to drill accurately positioned holes at precise angles when working away from a drill press. Combining the proven drilling accuracy of the Woodpeckers Auto-Line Drill Guide with a precision adjustable protractor base, it allows holes to be drilled at angles from 0° to 40° while keeping the drill bit aligned with the intended entry point.\u003c\/p\u003e\u003cp\u003eUnlike many angled drill guides, the AutoAngle uses a unique virtual pivot point positioned at the surface of the workpiece. This means the drill bit enters the material at the same location regardless of the drilling angle, allowing hole positions to be aligned directly to layout marks and crosshairs without recalculation.\u003c\/p\u003e\u003cp\u003eThe Deluxe version includes an adjustable fence system, flip stops and extended guide rods for repeatable drilling operations. The fence and stops can be configured to position holes at consistent distances from edges and corners, making the guide particularly useful for installation work, large assemblies and repetitive workshop tasks. Included centring buttons can also be used to locate holes in the centre of stock or align the guide on round material.\u003c\/p\u003e\u003cp\u003eLarge locking handles securely fix the drilling angle, while the non-slip base helps maintain position during use. The chuck carriage can be removed from the guide rods when required, providing a clear view of layout lines during setup.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers, installers and woodworkers drilling angled holes in large workpieces or on-site applications where a drill press cannot be used. Supplied with: Woodpeckers AutoAngle Drill Guide, fence, two 165mm (6-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) guide rods, six 279mm (11\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) guide rods, two flip stops, centring buttons and multi-knob.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036479865179,"sku":"114884","price":1044.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114884_xl.jpg?v=1793618675","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-autoangle-drill-guide-deluxe","provider":"Axminster Tools","version":"1.0","type":"link"}
