{"product_id":"woodpeckers-auxiliary-rip-fence-48","title":"Woodpeckers Auxiliary Rip Fence 48\"","description":"\u003cp\u003eThe Woodpeckers Auxiliary Rip Fence upgrades your existing table saw rip fence with a longer, taller and straighter reference surface for improved support, accuracy and versatility. Simply clamp it to your existing fence to create a substantial aluminium guide that provides greater support for workpieces on both the infeed and outfeed sides of the blade.\u003c\/p\u003e\u003cp\u003eBuilt around Woodpeckers' heavily ribbed aluminium SuperTrack, the Auxiliary Rip Fence measures 1,219mm (48\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) long and over 89mm (3-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) high. It can be positioned with more length ahead of or behind the blade depending on the task. The included material support can also be positioned on the infeed or outfeed side to help support larger workpieces and sheet material. Seven integrated T-tracks provide plenty of scope for adding compatible featherboards, stops and workshop jigs.\u003c\/p\u003e\u003cp\u003ePrecision-machined aluminium clamping blocks secure the Auxiliary Rip Fence to your existing fence using track clamps. The fence and clamping blocks together measure precisely 50.8mm (2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), allowing you to continue using your table saw's existing fence scale by adding 2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e to the required cutting dimension. The fence can be used in its standard high position for increased support, laid flat to create a 15.9mm (5\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) low fence for thin ripping, or raised above the table for use as an L-fence.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy, versatility and repeatability. Its products are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for woodworkers looking to get more versatility from their table saw, the Woodpeckers Auxiliary Rip Fence is useful for everything from ripping and handling large sheet material to working with tall or narrow stock. Its clamp-on design makes it suitable for a wide variety of existing table saw rip fences and allows quick removal when it isn't required. Supplied with Auxiliary Rip Fence and a material support.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036482978139,"sku":"114844","price":219.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114844_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-auxiliary-rip-fence-48","provider":"Axminster Tools","version":"1.0","type":"link"}
