The Woodpeckers Basic Slab Flattening Mill Pro provides a precise, router-based solution for flattening large slabs, tabletops, workbenches and other oversized timber that can be difficult or impossible to process using a conventional planer or thicknesser. Guiding your router over the workpiece in a controlled plane, it makes tackling wide, live-edge and irregular stock considerably easier.
Developed from the original Woodpeckers Slab Flattening Mill, the Pro features a redesigned router carriage with an increased thickness range and integrated dust collection at the cutting area. Twin dust pick-up points and a flexible full-surround curtain help capture waste close to the router cutter, making dust management more effective while you work. Its extended rails provide capacity for slabs up to 1,232 x 1,473mm (48.5 x 58).
The precisely engineered rail and carriage system controls the router's movement across the workpiece, creating a consistent reference plane for accurate surfacing. Maximum slab capacity is 1,232 x 1,473mm (48.5 x 58) when using a 51mm (2) diameter router cutter, with potential for additional width when using a larger suitable cutter.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop solutions designed to make demanding woodworking tasks more accurate and repeatable. Its Slab Flattening Mill system offers a practical solution to one of the challenges of working with large, natural-edge timber and oversized projects.
Ideal for furniture makers, professional workshops and ambitious home woodworkers working with live-edge slabs, glued panels, tabletops, countertops and workbenches, the Woodpeckers Basic Slab Flattening Mill Pro provides a controlled, accurate way to surface large material beyond the capacity of many conventional workshop machines.
Web Attribute Set Router Jigs & Templates
