{"product_id":"woodpeckers-basic-slab-flattening-mill-pro","title":"Woodpeckers Basic Slab Flattening Mill Pro","description":"\u003cp\u003eThe Woodpeckers Basic Slab Flattening Mill Pro provides a precise, router-based solution for flattening large slabs, tabletops, workbenches and other oversized timber that can be difficult or impossible to process using a conventional planer or thicknesser. Guiding your router over the workpiece in a controlled plane, it makes tackling wide, live-edge and irregular stock considerably easier.\u003c\/p\u003e\u003cp\u003eDeveloped from the original Woodpeckers Slab Flattening Mill, the Pro features a redesigned router carriage with an increased thickness range and integrated dust collection at the cutting area. Twin dust pick-up points and a flexible full-surround curtain help capture waste close to the router cutter, making dust management more effective while you work. Its extended rails provide capacity for slabs up to 1,232 x 1,473mm (48.5\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 58\u003cspecial id=\"32\"\u003e\u003c\/special\u003e).\u003c\/p\u003e\u003cp\u003eThe precisely engineered rail and carriage system controls the router's movement across the workpiece, creating a consistent reference plane for accurate surfacing. Maximum slab capacity is 1,232 x 1,473mm (48.5\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 58\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) when using a 51mm (2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter router cutter, with potential for additional width when using a larger suitable cutter.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop solutions designed to make demanding woodworking tasks more accurate and repeatable. Its Slab Flattening Mill system offers a practical solution to one of the challenges of working with large, natural-edge timber and oversized projects.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, professional workshops and ambitious home woodworkers working with live-edge slabs, glued panels, tabletops, countertops and workbenches, the Woodpeckers Basic Slab Flattening Mill Pro provides a controlled, accurate way to surface large material beyond the capacity of many conventional workshop machines.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036483207515,"sku":"114895","price":1339.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114895_xl.jpg?v=1793618675","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-basic-slab-flattening-mill-pro","provider":"Axminster Tools","version":"1.0","type":"link"}
