{"product_id":"woodpeckers-cam-a-line-deluxe-kit","title":"Woodpeckers Cam-A-Line Deluxe Kit","description":"\u003cp\u003eThe Woodpeckers Cam-A-Line Dowel Guide - Deluxe Kit provides a fast, accurate and highly adaptable solution for creating strong dowelled joints in a wide range of woodworking projects. Unlike fixed-spacing dowelling jigs, the Cam-A-Line uses an adjustable cam system that allows the spacing between drill bushings to be set to suit the workpiece, eliminating the limitations of preset hole patterns.\u003c\/p\u003e\u003cp\u003eThree guide bushings are linked by a sliding cam mechanism, allowing centre-to-centre spacing to be adjusted from 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 44.5mm (1-3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e). This enables equally spaced three-dowel layouts on stock from 57.2mm (2-1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 139.7mm (5-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide, while narrower and wider workpieces can be accommodated using fewer bushings or multiple dowel groups.\u003c\/p\u003e\u003cp\u003ePrecision-engraved centrelines make alignment straightforward. Simply mark across the joint, align the jig to the reference marks and drill. The result is accurately aligned dowel holes suitable for butt joints, mitre joints, T-joints and edge-glued panels. For repetitive work, the included stop system eliminates the need for repeated marking, speeding up production and improving consistency.\u003c\/p\u003e\u003cp\u003eThe Deluxe Kit includes four interchangeable guide bushing sizes, allowing the jig to be used with 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 7.9mm (5\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 9.5mm (3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) and 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) dowels. Also included are drill stop collars, stop blocks, stop extensions and a wall-mountable Rack-It for organised storage.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers producing strong, accurately aligned dowel joints, the Cam-A-Line offers exceptional flexibility across a wide range of joinery applications. Supplied with: Cam-A-Line Dowel Guide, 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 7.9mm (5\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 9.5mm (3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) and 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) guide bushings, drill stop collars, stop blocks, stop extensions and wall-mountable Rack-It.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036501852507,"sku":"114887","price":299.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114887_xl.jpg?v=1793618675","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-cam-a-line-deluxe-kit","provider":"Axminster Tools","version":"1.0","type":"link"}
