The Woodpeckers ClampZILLA 38
ClampZILLA applies both clamping forces by turning a single screw, simplifying panel glue-ups and reducing the need for separate bar clamps and clamping cauls. The latest design increases vertical clamping pressure and provides improved clearance for thicker workpieces, helping keep boards aligned as the joint closes.
Designed for material from 15.9mm (5/8
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers producing accurately aligned solid timber panels, the four-clamp set provides multiple clamping points across larger glue-ups for consistent pressure and alignment. Supplied with: four Woodpeckers ClampZILLA 965mm 4-Way Panel Clamps.
