The Woodpeckers ClampZILLA 50 4-Way Panel Clamps provides powerful, even clamping for larger panel glue-ups, applying horizontal and vertical pressure simultaneously. Bars positioned above and below the workpiece are connected by self-centring scissor joints, helping bring board edges together while keeping the faces aligned and reducing the risk of bowing.
ClampZILLA applies both clamping forces by turning a single screw, simplifying glue-ups and reducing the need for separate bar clamps and cauls. The latest design provides increased vertical pressure and improved clearance for thicker workpieces, helping keep individual boards aligned as the joints close.
Each ClampZILLA has a generous 1,270mm (50) capacity and accommodates material from 15.9mm (5/8) to 101.6mm (4) thick. The Acme-threaded clamping mechanism provides substantial pressure, while the four-clamp set allows pressure to be distributed across larger panels such as dining tables, worktops and wide furniture components.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers producing large solid timber panels, this four-pack provides multiple clamping points for consistent pressure and accurate alignment across the glue-up. Supplied with: four Woodpeckers ClampZILLA 1,270mm (50) 4-Way Panel Clamps.
Web Attribute Set Panel Clamps
