{"product_id":"woodpeckers-clampzilla-2022-50-capacity-4-pack","title":"Woodpeckers Clampzilla 2022, 50\" Capacity 4 Pack","description":"\u003cp\u003eThe Woodpeckers ClampZILLA 50\u003cspecial id=\"32\"\u003e\u003c\/special\u003e 4-Way Panel Clamps provides powerful, even clamping for larger panel glue-ups, applying horizontal and vertical pressure simultaneously. Bars positioned above and below the workpiece are connected by self-centring scissor joints, helping bring board edges together while keeping the faces aligned and reducing the risk of bowing.\u003c\/p\u003e\u003cp\u003eClampZILLA applies both clamping forces by turning a single screw, simplifying glue-ups and reducing the need for separate bar clamps and cauls. The latest design provides increased vertical pressure and improved clearance for thicker workpieces, helping keep individual boards aligned as the joints close.\u003c\/p\u003e\u003cp\u003eEach ClampZILLA has a generous 1,270mm (50\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) capacity and accommodates material from 15.9mm (5\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 101.6mm (4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick. The Acme-threaded clamping mechanism provides substantial pressure, while the four-clamp set allows pressure to be distributed across larger panels such as dining tables, worktops and wide furniture components.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers producing large solid timber panels, this four-pack provides multiple clamping points for consistent pressure and accurate alignment across the glue-up. Supplied with: four Woodpeckers ClampZILLA 1,270mm (50\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) 4-Way Panel Clamps.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036502049115,"sku":"114889","price":999.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114889_xl.jpg?v=1793618675","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-clampzilla-2022-50-capacity-4-pack","provider":"Axminster Tools","version":"1.0","type":"link"}
