{"product_id":"woodpeckers-clampzilla","title":"Woodpeckers Clampzilla","description":"\u003cp\u003eThe Woodpeckers ClampZILLA 38\u003cspecial id=\"32\"\u003e\u003c\/special\u003e 4-Way Panel Clamps - 4 Pack provides powerful, even clamping for panel glue-ups, applying both horizontal and vertical pressure at the same time. Bars positioned above and below the workpiece are connected by self-centring scissor joints, helping bring board edges together while keeping the faces aligned and reducing the tendency for panels to bow.\u003c\/p\u003e\u003cp\u003eClampZILLA applies both clamping forces by turning a single screw, simplifying panel glue-ups and reducing the need for separate bar clamps and clamping cauls. The latest design increases vertical clamping pressure and provides improved clearance for thicker workpieces, helping keep boards aligned as the joint closes.\u003c\/p\u003e\u003cp\u003eDesigned for material from 15.9mm (5\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 101.6mm (4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick, ClampZILLA uses an Acme-threaded clamping screw with self-centring joints at either end. Each clamp has a working capacity of 965mm (38\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), making this four-pack particularly suitable for larger panel glue-ups such as tabletops, cabinet panels and furniture components.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers producing accurately aligned solid timber panels, the four-clamp set provides multiple clamping points across larger glue-ups for consistent pressure and alignment. Supplied with: four Woodpeckers ClampZILLA 965mm 4-Way Panel Clamps.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036502016347,"sku":"114866","price":929.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114866_xl.jpg?v=1793618596","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-clampzilla","provider":"Axminster Tools","version":"1.0","type":"link"}
