{"product_id":"woodpeckers-csp-clamp-rack-it-2-csp-cspc2","title":"Woodpeckers CSP Clamp Rack-It, 2 CSP, CSPC2","description":"\u003cp\u003eThe Woodpeckers CSP Clamp Rack-It provides a complete assembly and storage solution for keeping panels, cabinets, boxes and carcasses accurately aligned during glue-ups and assembly. Combining Clamping Squares Plus, CSP Clamps and a dedicated wall-mounted Rack-It, the system helps maintain accurate 90° alignment while keeping all components organised and ready for use. The 12 Piece Kit + Rack-It includes four Clamping Squares Plus, eight CSP Clamps and a custom storage Rack-It for convenient workshop organisation.\u003c\/p\u003e\u003cp\u003eThe Clamping Squares Plus are CNC machined from solid aluminium to a stated tolerance of ±0.0255°, providing a precise reference for assembly work. Each square measures 171.5mm (6-3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) long, 31.8mm (1-1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide and 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick, and can be used on either the inside or outside of a corner. A relief cut in the inside corner prevents binding if material is slightly out of square.\u003c\/p\u003e\u003cp\u003eThe included CSP Clamps are designed specifically for use with the Clamping Squares Plus, locking directly into the integrated 9.5mm (3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) holes for quick positioning and secure clamping. Featuring aluminium jaws and fast-running Acme threads, they accommodate material from 4.8mm (3\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 50.8mm (2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick while helping prevent surface marking during normal use.\u003c\/p\u003e\u003cp\u003eThe powder-coated Rack-It keeps both the squares and clamps organised and easily accessible, with storage for the full kit. This makes it ideal for workshops where quick access and efficient workflow are important.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers assembling boxes, cabinets, drawers and panels, the CSP system helps speed up assembly while maintaining accurate alignment. Supplied with: four Clamping Squares Plus, eight CSP Clamps, CSP Clamp Rack-It and mounting screws.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036502507867,"sku":"114849","price":329.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114849_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-csp-clamp-rack-it-2-csp-cspc2","provider":"Axminster Tools","version":"1.0","type":"link"}
