{"product_id":"woodpeckers-dado-nut-for-sawstop","title":"Woodpeckers Dado Nut For Sawstop","description":"\u003cp\u003eThe Woodpeckers Dado Nut for SawStop combines the arbor nut and washer into one compact unit, allowing a full 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) dado stack to be fitted while maintaining full thread engagement on compatible SawStop table saws. Designed for SawStop models built after 2014, it provides the support of an arbor washer without taking up additional space on the arbor.\u003c\/p\u003e\u003cp\u003eBy integrating the washer and nut, the Dado Nut provides a stable clamping surface against the dado stack while maximising the available thread. The nut is retained within the washer, making installation and blade changes straightforward using the standard SawStop arbor wrenches.\u003c\/p\u003e\u003cp\u003ePrecision machined for flatness and thread accuracy, the Dado Nut uses 15.9mm (5\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e)-12 TPI right-hand Acme threads. It replaces the standard factory arbor washer and nut and requires no additional tools or modification to the saw. This version is intended for compatible SawStop models built after 2014 and is not suitable for saws with left-hand arbor threads.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for SawStop owners using a stacked dado blade who need to maximise the available arbor thread while retaining washer support. Check your saw model, age and arbor thread before use. Supplied: One Woodpeckers Dado Nut for SawStop.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036504441179,"sku":"114890","price":59.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114890_xl.jpg?v=1793618676","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-dado-nut-for-sawstop","provider":"Axminster Tools","version":"1.0","type":"link"}
