{"product_id":"woodpeckers-dp-pro-master-system-36-36","title":"Woodpeckers Dp-Pro Master System 36\/36","description":"\u003cp\u003eThe Woodpeckers DP-PRO Master System 36\/36 transforms a drill press into a more capable woodworking machine, combining a large adjustable table, dust-collecting fence, drawer base, flip stops and clamps in one complete system. Designed to fit a wide range of drill presses, it installs quickly while maintaining access to the machine's normal adjustments.\u003c\/p\u003e\u003cp\u003eAt the heart of the system is the DP-PRO Fence, which provides support for both horizontal and vertical drilling operations. The hollow fence doubles as a dust extraction duct, collecting chips and dust directly at the source. A dust extractor or vacuum can be connected to either end of the fence, helping keep the work area cleaner during use. Two micro-adjustable flip stops mount to the fence and can be positioned on either side of the drill bit for repeatable drilling operations.\u003c\/p\u003e\u003cp\u003eThe DP-PRO Table features extension wings that increase its width from 610mm (24\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) when closed to 914mm (36\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) when fully extended. Constructed from 25.4mm (1\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick Baltic birch plywood with a low-friction Micro-Dot laminate surface, it incorporates DP-Tracks for attaching the fence and hold-downs. A replaceable insert extends service life by allowing multiple indexing positions. The DP-PRO Drawer Base raises the table 102mm (4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) above the drill press table, providing clearance for elevation cranks while adding convenient storage for frequently used accessories.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers looking to improve the accuracy, support and versatility of their drill press, the DP-PRO Master System 36\/36 provides a complete woodworking-focused solution. Supplied with: Woodpeckers DP-PRO Drawer Base, DP-PRO Table with extension wings, DP-PRO Fence 914mm (36\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), two DP-PRO Flip Stops and two Knuckle Clamps.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55174489866587,"sku":"114893","price":1150.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114893_xl.jpg?v=1794300741","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-dp-pro-master-system-36-36","provider":"Axminster Tools","version":"1.0","type":"link"}
