The Woodpeckers Drill Press Protractor is a precision setup tool for accurately setting and checking angles on your drill press, band saw, mitre gauge and other workshop equipment. Its easy-to-read vernier scale provides fine angle adjustment, making it particularly useful for angled joinery, furniture making and accurate machine setup.
The reversible vernier offers a choice of degrees and minutes or quarter-degree graduations, allowing angles to be set as precisely as 5 minutes of a degree. Once set, the shaft can be mounted in the drill press chuck, providing an accurate reference for adjusting the table to the required angle. Set to 0°, it also provides a straightforward way to return the drill press table to square.
A V-groove precision machined into the base helps locate round stock for drilling accurately on its centreline. Beyond the drill press, the Protractor can be used to set and check mitre gauges, transfer angles to a bevel gauge and set a band saw table relative to the blade. Its round shaft provides a useful reference against the body of a band saw blade without interference from the teeth.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers tackling angled joinery or looking for greater precision when setting up workshop machinery, the Drill Press Protractor provides an accurate and versatile angle reference. Supplied: One Woodpeckers Drill Press Protractor.
