The Woodpeckers Exact-90 Flip Stop is a dedicated accessory for the Woodpeckers Exact-90 Mitre Gauge, providing an additional or replacement stop for accurate, repeatable cutting. It fits directly onto the Exact-90 fence, allowing workpieces to be positioned consistently when producing multiple components to the same length.
Designed for quick, accurate adjustment, the Flip Stop allows the position of the stop to be fine-tuned without tapping or nudging it into place. Once set, it provides a positive reference for the end of the workpiece, helping make repetitive crosscutting quicker and more consistent.
The Flip Stop works with the graduated and extendable fence of the Exact-90 Mitre Gauge and can be repositioned along the fence to suit the required cutting length. Adjustments are tool-free, making it straightforward to change settings between different cutting operations.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal as a replacement or additional stop for woodworkers using the Woodpeckers Exact-90 Mitre Gauge for repetitive crosscutting. Compatible exclusively with the Woodpeckers Exact-90 Mitre Gauge fence SKU 114865. Supplied: One Woodpeckers Exact-90 Flip Stop.
Web Attribute Set Mitre Saw Accessories
