The Woodpeckers Extended Slab Flattening Mill Pro provides a precise, router-based solution for flattening exceptionally long slabs, tabletops, workbenches and other oversized timber that can be difficult or impossible to process using a conventional planer or thicknesser. Its extended working capacity accommodates slabs up to 1,232 x 3,404mm (48.5
The Pro system features a redesigned router carriage with an increased thickness range and integrated dust collection at the cutting area. Twin dust pick-up points and a flexible full-surround curtain help capture waste close to the router cutter, while the extended rail system provides the additional length needed for surfacing particularly long workpieces.
The precisely engineered rail and carriage system guides your router over the workpiece in a controlled plane for consistent, accurate surfacing. Maximum slab capacity is 1,232 x 3,404mm (48.5
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop solutions designed to make demanding woodworking tasks more accurate and repeatable. Its Slab Flattening Mill system provides a practical solution for surfacing large, natural-edge and oversized timber.
Ideal for furniture makers, professional workshops and ambitious home woodworkers tackling long live-edge slabs, dining tables, countertops, workbenches and large glued panels, the Woodpeckers Extended Slab Flattening Mill Pro provides the capacity and control required for large-scale slab surfacing projects.
