{"product_id":"woodpeckers-extended-slab-flattening-mill-pro","title":"Woodpeckers Extended Slab Flattening Mill Pro","description":"\u003cp\u003eThe Woodpeckers Extended Slab Flattening Mill Pro provides a precise, router-based solution for flattening exceptionally long slabs, tabletops, workbenches and other oversized timber that can be difficult or impossible to process using a conventional planer or thicknesser. Its extended working capacity accommodates slabs up to 1,232 x 3,404mm (48.5\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 134\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), making it ideal for ambitious large-scale projects.\u003c\/p\u003e\u003cp\u003eThe Pro system features a redesigned router carriage with an increased thickness range and integrated dust collection at the cutting area. Twin dust pick-up points and a flexible full-surround curtain help capture waste close to the router cutter, while the extended rail system provides the additional length needed for surfacing particularly long workpieces.\u003c\/p\u003e\u003cp\u003eThe precisely engineered rail and carriage system guides your router over the workpiece in a controlled plane for consistent, accurate surfacing. Maximum slab capacity is 1,232 x 3,404mm (48.5\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 134\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) when using a 51mm (2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) diameter router cutter, with the potential for additional width when using a larger suitable cutter.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop solutions designed to make demanding woodworking tasks more accurate and repeatable. Its Slab Flattening Mill system provides a practical solution for surfacing large, natural-edge and oversized timber.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, professional workshops and ambitious home woodworkers tackling long live-edge slabs, dining tables, countertops, workbenches and large glued panels, the Woodpeckers Extended Slab Flattening Mill Pro provides the capacity and control required for large-scale slab surfacing projects.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036523184475,"sku":"114902","price":1599.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114902_xl.jpg?v=1793618688","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-extended-slab-flattening-mill-pro","provider":"Axminster Tools","version":"1.0","type":"link"}
