{"product_id":"woodpeckers-flush-trim-base","title":"Woodpeckers Flush Trim Base","description":"\u003cp\u003eThe Woodpeckers Flush Trim Base provides a stable and accurate way to trim solid wood edge banding flush with panel surfaces using a router. By supporting the router vertically against the face of the panel, it offers greater control than a standard router base while reducing the risk of tipping, gouging or damaging the workpiece.\u003c\/p\u003e\u003cp\u003eBuilt around a substantial 152.4mm x 381mm (6\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 15\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) solid phenolic base, the Flush Trim Base provides a large reference surface that rides on the face of the panel. A relieved section beneath the router mounting area clears material projecting up to 3.2mm (1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) above the panel surface, allowing edge banding to be trimmed accurately while leaving the panel face untouched.\u003c\/p\u003e\u003cp\u003eThe base supports several trimming methods depending on the application. An adjustable fence is included for repetitive edge-banding work on shelves and panels, while a bearing-guided cutter can be used for trimming curved and shaped components. For full perimeter trimming, the large base provides ample support when working without the fence.\u003c\/p\u003e\u003cp\u003eThe Flush Trim Base is compatible with many popular corded and cordless trim routers and also fits 1-1\/2hp routers with a standard Porter-Cable three-screw base pattern. Beyond edge banding, it is equally useful for flushing through tenons, exposed dowels, bridle joints, half-lap joints and similar proud joinery.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for cabinetmakers, furniture makers and woodworkers using solid wood lippings and exposed joinery, the Flush Trim Base delivers greater stability, cleaner results and faster trimming than traditional hand-tool methods. Supplied with: Woodpeckers Flush Trim Base and adjustable fence.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036523381083,"sku":"114875","price":159.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114875_xl.jpg?v=1793618643","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-flush-trim-base","provider":"Axminster Tools","version":"1.0","type":"link"}
