The Woodpeckers Flush Trim Base provides a stable and accurate way to trim solid wood edge banding flush with panel surfaces using a router. By supporting the router vertically against the face of the panel, it offers greater control than a standard router base while reducing the risk of tipping, gouging or damaging the workpiece.
Built around a substantial 152.4mm x 381mm (6
The base supports several trimming methods depending on the application. An adjustable fence is included for repetitive edge-banding work on shelves and panels, while a bearing-guided cutter can be used for trimming curved and shaped components. For full perimeter trimming, the large base provides ample support when working without the fence.
The Flush Trim Base is compatible with many popular corded and cordless trim routers and also fits 1-1/2hp routers with a standard Porter-Cable three-screw base pattern. Beyond edge banding, it is equally useful for flushing through tenons, exposed dowels, bridle joints, half-lap joints and similar proud joinery.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for cabinetmakers, furniture makers and woodworkers using solid wood lippings and exposed joinery, the Flush Trim Base delivers greater stability, cleaner results and faster trimming than traditional hand-tool methods. Supplied with: Woodpeckers Flush Trim Base and adjustable fence.
