The Woodpeckers Folding Saddle Square Set makes it quick and easy to transfer accurate layout lines around corners and across adjacent faces. Designed for precision joinery, the hinged squares wrap around your workpiece, helping maintain alignment as you mark from one face to another.
Unlike traditional layout tools that require you to reposition your square several times, the Folding Saddle Square acts like a hinged straightedge. The edges are precision milled after final assembly, ensuring both halves sit accurately in plane with one another. The hinge is tensioned to eliminate lateral play while allowing smooth adjustment, so the square can follow both 90° corners and wider angles.
The Deluxe Set includes two sizes for different scales of work. The larger square measures 38mm wide x 190mm overall length, while the smaller measures 25.4mm wide x 127mm overall length. They are ideal for marking tenon shoulders and cheeks, aligning cross-dowel joinery and transferring matching layout lines between adjacent faces. They can also be adjusted beyond 90° for work such as angled bridle joints and multi-sided projects.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed for accurate, repeatable work. Its tools are precisely machined and carefully inspected at the company's facility in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers carrying out accurate joinery and layout work, the Woodpeckers Folding Saddle Square Set makes transferring a measurement around a corner simpler and more reliable. The Deluxe Set includes both the large and small Folding Saddle Squares, providing a choice of size for everything from smaller components to larger joinery.
Web Attribute Set Laying Out Tools
