{"product_id":"woodpeckers-free-hand-guard-2-0","title":"Woodpeckers Free Hand Guard 2.0","description":"\u003cp\u003eThe Woodpeckers Freehand Guard 2.0 improves safety, visibility and dust extraction when routing curved and irregular workpieces on a router table. Designed for freehand routing operations where a fence would be impractical, it covers the cutter while providing clear visibility of the work area and effective chip collection at the source.\u003c\/p\u003e\u003cp\u003eTwo integrated starting fulcrum points provide controlled support as the workpiece is introduced to the cutter, functioning in a similar way to a starter pin. A clear acrylic guard helps shield the cutter while maintaining an unobstructed view of the routing operation, making it easier to follow profiles and control the workpiece.\u003c\/p\u003e\u003cp\u003eThe updated design accommodates material up to 44.5mm (1-3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick and includes captive mounting knobs that remain attached to the guard when removed from the router table. An integrated dust port accepts 63.5mm (2-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) dust extraction hose or 57.2mm (2-1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) shop vacuum hose, helping capture the majority of chips and dust produced during routing.\u003c\/p\u003e\u003cp\u003eThe Freehand Guard 2.0 mounts to compatible Woodpeckers router lifts, router plates and the StabilMax RT+ Router Base using existing starter pin mounting positions. It can also be fitted to other router plates by drilling and tapping suitable 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e-20 mounting holes.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for freehand edge profiling, template work and shaping operations on a router table, the Woodpeckers Freehand Guard 2.0 provides improved control, cleaner working and enhanced cutter protection. Supplied: One Woodpeckers Freehand Guard 2.0.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036524069211,"sku":"114868","price":49.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114868_xl.jpg?v=1793618643","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-free-hand-guard-2-0","provider":"Axminster Tools","version":"1.0","type":"link"}
