The Woodpeckers Joinery Sled is a versatile precision jig designed for accurate joinery operations on both table saws and router tables. With extensive adjustment capability, micro-adjustment control and flexible workholding options, it simplifies the production of accurate joints while reducing the need for dedicated single-purpose jigs.
The sled's adjustable base provides a total of 228.6mm (9) of travel, combining 139.7mm (5-1/2) of adjustment in the main base with a further 88.9mm (3-1/2) in the upper sliding platform. Four bearing-guided supports ensure smooth movement, while the integrated micro-adjuster allows fine positioning changes with precise control when fitting joints.
The work table can be locked anywhere between 44° and 91°, making the sled suitable for both standard square joinery and more complex angled work. Three track-clamp slots provide flexible workholding options, while the adjustable fence can be mounted at either end of the table and positioned at a wide range of angles. A sacrificial fence face supports the workpiece as the cutter exits the material for cleaner results.
The patented mitre bar uses nylon leaf springs to compensate for wear and dimensional variation in standard 19.1mm x 9.5mm (3/4 x 3/8) mitre slots, helping maintain smooth, accurate travel on a wide range of machines.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers producing precise joints on either a router table or table saw, the Joinery Sled offers versatile workholding, accurate adjustment and repeatable setup. Supplied with: Woodpeckers Joinery Sled, two pivot clamps, sacrificial fence face and wall-mountable Rack-It.
Web Attribute Set Saw Bench Accessories
