{"product_id":"woodpeckers-joinery-sled","title":"Woodpeckers Joinery Sled","description":"\u003cp\u003eThe Woodpeckers Joinery Sled is a versatile precision jig designed for accurate joinery operations on both table saws and router tables. With extensive adjustment capability, micro-adjustment control and flexible workholding options, it simplifies the production of accurate joints while reducing the need for dedicated single-purpose jigs.\u003c\/p\u003e\u003cp\u003eThe sled's adjustable base provides a total of 228.6mm (9\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) of travel, combining 139.7mm (5-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) of adjustment in the main base with a further 88.9mm (3-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) in the upper sliding platform. Four bearing-guided supports ensure smooth movement, while the integrated micro-adjuster allows fine positioning changes with precise control when fitting joints.\u003c\/p\u003e\u003cp\u003eThe work table can be locked anywhere between 44° and 91°, making the sled suitable for both standard square joinery and more complex angled work. Three track-clamp slots provide flexible workholding options, while the adjustable fence can be mounted at either end of the table and positioned at a wide range of angles. A sacrificial fence face supports the workpiece as the cutter exits the material for cleaner results.\u003c\/p\u003e\u003cp\u003eThe patented mitre bar uses nylon leaf springs to compensate for wear and dimensional variation in standard 19.1mm x 9.5mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) mitre slots, helping maintain smooth, accurate travel on a wide range of machines.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers producing precise joints on either a router table or table saw, the Joinery Sled offers versatile workholding, accurate adjustment and repeatable setup. Supplied with: Woodpeckers Joinery Sled, two pivot clamps, sacrificial fence face and wall-mountable Rack-It.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036525838683,"sku":"114874","price":449.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114874_xl.jpg?v=1793618643","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-joinery-sled","provider":"Axminster Tools","version":"1.0","type":"link"}
