The Woodpeckers Joint Bridges helps keep boards level during panel glue-ups by applying pressure directly at each joint line. Designed to reduce the effects of minor twist, cup and bow in timber, the Joint Bridges help align adjoining board faces, resulting in flatter glue-ups that require less planing and sanding after assembly.
Unlike traditional clamping cauls, Joint Bridges localise clamping pressure at each joint, helping adjacent boards align more accurately as the clamps are tightened. This makes them particularly useful when gluing up table tops, panels, cutting boards and cabinet components where face alignment is important.
The design also works well when creating cutting boards with decorative through-inlays, allowing inlay strips to sit up to 12.7mm (1/2
A pack of twelve Joint Bridges provides enough pads for the ends of a four-board panel glue-up, while their compact size makes them easy to position exactly where support is needed.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers looking to achieve flatter, better-aligned glue-ups with less finishing work afterwards.
Supplied with: 12 Joint Bridges.
