{"product_id":"woodpeckers-joint-bridge-set-12-pce","title":"Woodpeckers Joint Bridge Set 12 Pce","description":"\u003cp\u003eThe Woodpeckers Joint Bridges helps keep boards level during panel glue-ups by applying pressure directly at each joint line. Designed to reduce the effects of minor twist, cup and bow in timber, the Joint Bridges help align adjoining board faces, resulting in flatter glue-ups that require less planing and sanding after assembly.\u003c\/p\u003e\u003cp\u003eUnlike traditional clamping cauls, Joint Bridges localise clamping pressure at each joint, helping adjacent boards align more accurately as the clamps are tightened. This makes them particularly useful when gluing up table tops, panels, cutting boards and cabinet components where face alignment is important.\u003c\/p\u003e\u003cp\u003eThe design also works well when creating cutting boards with decorative through-inlays, allowing inlay strips to sit up to 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) proud of the main board without interfering with the clamping process. Manufactured from durable glass-fibre reinforced polycarbonate, the Joint Bridges are resistant to workshop wear and are suitable for use as protective clamp pads on metal-faced clamps.\u003c\/p\u003e\u003cp\u003eA pack of twelve Joint Bridges provides enough pads for the ends of a four-board panel glue-up, while their compact size makes them easy to position exactly where support is needed.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers looking to achieve flatter, better-aligned glue-ups with less finishing work afterwards.\u003c\/p\u003e\u003cp\u003eSupplied with: 12 Joint Bridges.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036526035291,"sku":"114854","price":58.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114854_xl.jpg?v=1793618496","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-joint-bridge-set-12-pce","provider":"Axminster Tools","version":"1.0","type":"link"}
