The Woodpeckers Juice Groove Jig makes it quick and easy to add professional-looking juice grooves to cutting boards of varying sizes. Ideal for both one-off projects and batch production, the jig adjusts rapidly to suit different board dimensions without the need for dedicated templates.
The jig accommodates square and rectangular cutting boards from approximately 260mm x 260mm (10-1/4 x 10-1/4) up to 476mm x 476mm (18-3/4 x 18-3/4), depending on router base size and the margin required. Four ratcheting corner knobs allow fast adjustment, while the rigid 11-gauge steel rails provide a stable guide for the router, helping achieve smooth, consistent results.
Unlike many juice groove jigs, the router base runs directly on the workpiece, eliminating the need for a guide bush or router base extension. Suitable for use with plunge routers, palm routers and standard routers, the jig works with both dedicated juice groove cutters and standard core box bits. The groove position can be customised by varying the spacing between the jig and the edge of the cutting board.
The 50.8mm (2) deep rails allow use on boards from 19.1mm (3/4) to 47.6mm (1-7/8) thick. Thicker workpieces can also be accommodated using suitable spacers beneath the jig.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for cutting board makers, furniture makers and woodworkers looking to add decorative and functional juice grooves efficiently and accurately. Supplied: One Woodpeckers Juice Groove Jig.
Web Attribute Set Router Jigs & Templates
EAN Barcode 0810137209692
