{"product_id":"woodpeckers-juice-groove-jig","title":"Woodpeckers Juice Groove Jig","description":"\u003cp\u003eThe Woodpeckers Juice Groove Jig makes it quick and easy to add professional-looking juice grooves to cutting boards of varying sizes. Ideal for both one-off projects and batch production, the jig adjusts rapidly to suit different board dimensions without the need for dedicated templates.\u003c\/p\u003e\u003cp\u003eThe jig accommodates square and rectangular cutting boards from approximately 260mm x 260mm (10-1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 10-1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) up to 476mm x 476mm (18-3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 18-3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), depending on router base size and the margin required. Four ratcheting corner knobs allow fast adjustment, while the rigid 11-gauge steel rails provide a stable guide for the router, helping achieve smooth, consistent results.\u003c\/p\u003e\u003cp\u003eUnlike many juice groove jigs, the router base runs directly on the workpiece, eliminating the need for a guide bush or router base extension. Suitable for use with plunge routers, palm routers and standard routers, the jig works with both dedicated juice groove cutters and standard core box bits. The groove position can be customised by varying the spacing between the jig and the edge of the cutting board.\u003c\/p\u003e\u003cp\u003eThe 50.8mm (2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) deep rails allow use on boards from 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 47.6mm (1-7\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick. Thicker workpieces can also be accommodated using suitable spacers beneath the jig.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for cutting board makers, furniture makers and woodworkers looking to add decorative and functional juice grooves efficiently and accurately. Supplied: One Woodpeckers Juice Groove Jig.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036526428507,"sku":"114869","price":149.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114869_xl.jpg?v=1793618643","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-juice-groove-jig","provider":"Axminster Tools","version":"1.0","type":"link"}
