The Woodpeckers Mini Square is a compact precision square designed specifically for checking the squareness of chisels, plane irons and other edge tools. Its small size makes it easier to position around tool handles and confined areas where a conventional engineer's or woodworking square can be awkward to use.
With an internal size of 28.6mm x 50.8mm (1-1/8 x 2), the Mini Square provides a practical reference for sharpening, honing and setting up cutting tools. The lightweight aluminium construction is easy to hold and, unlike steel squares, is less likely to damage tool edges if accidental contact occurs.
The red anodised finish provides strong contrast against steel tool surfaces, making it easier to spot gaps when checking for square. Compact enough to carry in a pocket or tool roll, the Mini Square is supplied in its own fitted storage tray for protection when not in use.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for sharpening, tool setup and checking cutting edges, the Woodpeckers Mini Square provides a quick and accurate way to verify squareness on workshop tools. Woodpeckers state the square is guaranteed to remain within 0.025mm (0.001) of square. Supplied: One Woodpeckers Mini Square.
Web Attribute Set Squares
