{"product_id":"woodpeckers-mini-square","title":"Woodpeckers Mini Square","description":"\u003cp\u003eThe Woodpeckers Mini Square is a compact precision square designed specifically for checking the squareness of chisels, plane irons and other edge tools. Its small size makes it easier to position around tool handles and confined areas where a conventional engineer's or woodworking square can be awkward to use.\u003c\/p\u003e\u003cp\u003eWith an internal size of 28.6mm x 50.8mm (1-1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), the Mini Square provides a practical reference for sharpening, honing and setting up cutting tools. The lightweight aluminium construction is easy to hold and, unlike steel squares, is less likely to damage tool edges if accidental contact occurs.\u003c\/p\u003e\u003cp\u003eThe red anodised finish provides strong contrast against steel tool surfaces, making it easier to spot gaps when checking for square. Compact enough to carry in a pocket or tool roll, the Mini Square is supplied in its own fitted storage tray for protection when not in use.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for sharpening, tool setup and checking cutting edges, the Woodpeckers Mini Square provides a quick and accurate way to verify squareness on workshop tools. Woodpeckers state the square is guaranteed to remain within 0.025mm (0.001\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) of square. Supplied: One Woodpeckers Mini Square.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036528492891,"sku":"114842","price":33.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114842_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-mini-square","provider":"Axminster Tools","version":"1.0","type":"link"}
