{"product_id":"woodpeckers-mortising-jig","title":"Woodpeckers Mortising Jig","description":"\u003cp\u003eThe Woodpeckers Mortising Jig provides a precise and versatile way to cut mortises using a plunge router and straight router cutter. Designed for loose-tenon joinery, it allows accurate mortises from 3.2mm (1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide and up to 88.9mm (3-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) long, making it suitable for everything from furniture and cabinet construction to more complex joinery.\u003c\/p\u003e\u003cp\u003eThe vertical table features clamp slots running in both directions, making it easy to secure the workpiece and position the supplied fence. The fence can be used vertically, horizontally or at an angle to suit different joint layouts. A low-friction horizontal table provides a smooth surface for the router, while the included guide bush works with the jig to control the mortise width. Laser-engraved metric and imperial scales aid accurate positioning and setup.\u003c\/p\u003e\u003cp\u003eThe Mortising Jig can be clamped to a conventional workbench or mounted to compatible 20mm bench holes on 96mm centres, including Festool MFT-style and Woodpeckers Track Clamp Tables. Suitable metric router cutters can also be used to produce mortises sized for compatible Festool Domino loose tenons, allowing the jig to be used with ready-made tenons as well as shop-made loose tenon stock.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers who want to create accurate loose-tenon joints using a plunge router, the Woodpeckers Mortising Jig provides a flexible alternative to a dedicated mortising system. Supplied with: Woodpeckers Mortising Jig, fence and guide bush.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036528918875,"sku":"114903","price":311.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114903_xl.jpg?v=1793618688","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-mortising-jig","provider":"Axminster Tools","version":"1.0","type":"link"}
