The Woodpeckers Rout-N-Plane XL Benchtop Board Mill provides a practical solution for flattening and surfacing workpieces that are too wide or unsuitable for a thickness planer. Designed for end-grain cutting boards, wide glued-up panels, workbenches, river tables and slab projects, it allows a router to be guided accurately across the surface to create flat, parallel faces. The XL Model increases surfacing capacity to workpieces up to 609.6mm (24) wide.
Suitable for material from 19.1mm (3/4) to 76.2mm (3) thick, the Rout-N-Plane XL adjusts quickly to accommodate different workpiece sizes. Once the workpiece is secured to a flat surface, the system supports the router while guiding it evenly across the board, making it easy to remove high spots and create a flat reference surface.
The powder-coated support structure provides smooth movement and low friction, while adjustable height settings allow the router to be positioned just above the workpiece before cutting. A sacrificial fence helps keep the system aligned to the project, and a centring guide is included to assist with positioning router edge guides. The XL version is designed for workbenches or tables at least 812.8mm (32) wide.
Compatible with everything from compact trim routers to large production routers, the Rout-N-Plane XL offers a versatile surfacing solution without the need for specialist wide-capacity machinery.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cutting board makers, cabinetmakers and woodworkers surfacing oversized panels or end-grain projects, the Rout-N-Plane XL extends the capability of a standard router into a highly effective benchtop board mill. Supplied with: Woodpeckers Rout-N-Plane XL Benchtop Board Mill, centring guide and sacrificial fence.
Web Attribute Set Router Jigs & Templates
