{"product_id":"woodpeckers-rout-n-plane-benchtop-board-mill","title":"Woodpeckers Rout-N-Plane Benchtop Board Mill","description":"\u003cp\u003eThe Woodpeckers Rout-N-Plane XL Benchtop Board Mill provides a practical solution for flattening and surfacing workpieces that are too wide or unsuitable for a thickness planer. Designed for end-grain cutting boards, wide glued-up panels, workbenches, river tables and slab projects, it allows a router to be guided accurately across the surface to create flat, parallel faces. The XL Model increases surfacing capacity to workpieces up to 609.6mm (24\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide.\u003c\/p\u003e\u003cp\u003eSuitable for material from 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 76.2mm (3\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick, the Rout-N-Plane XL adjusts quickly to accommodate different workpiece sizes. Once the workpiece is secured to a flat surface, the system supports the router while guiding it evenly across the board, making it easy to remove high spots and create a flat reference surface.\u003c\/p\u003e\u003cp\u003eThe powder-coated support structure provides smooth movement and low friction, while adjustable height settings allow the router to be positioned just above the workpiece before cutting. A sacrificial fence helps keep the system aligned to the project, and a centring guide is included to assist with positioning router edge guides. The XL version is designed for workbenches or tables at least 812.8mm (32\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide.\u003c\/p\u003e\u003cp\u003eCompatible with everything from compact trim routers to large production routers, the Rout-N-Plane XL offers a versatile surfacing solution without the need for specialist wide-capacity machinery.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cutting board makers, cabinetmakers and woodworkers surfacing oversized panels or end-grain projects, the Rout-N-Plane XL extends the capability of a standard router into a highly effective benchtop board mill. Supplied with: Woodpeckers Rout-N-Plane XL Benchtop Board Mill, centring guide and sacrificial fence.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036547498331,"sku":"114888","price":269.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114888_xl.jpg?v=1793618676","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-rout-n-plane-benchtop-board-mill","provider":"Axminster Tools","version":"1.0","type":"link"}
