The Woodpeckers Router Plane Spear Point Blade Only is a genuine replacement cutter for the Woodpeckers Router Plane. The spear-point profile is designed to provide improved access into corners and confined areas that can be difficult to reach with a standard straight cutter, making it particularly useful when refining detailed joinery.
Compatible with the multiple blade positions and orientations available on the Woodpeckers Router Plane, the spear-point blade helps reach awkward areas while maintaining the precise depth control required for fine fitting work. It is ideal for cleaning up the bottoms of joints and reaching into areas where a conventional straight blade may have limited access.
The blade features a lapped and polished back and requires only light honing before use. It is designed specifically for use with the Woodpeckers Router Plane and fits securely within the tool's double-wedge blade retention system.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for cabinetmakers, furniture makers and hand-tool woodworkers who require greater access when refining complex joinery and detailed work. Supplied: One Woodpeckers Router Plane Spear Point Blade.
Web Attribute Set Hand Plane Blades
