{"product_id":"woodpeckers-router-plane-straight-blade-only","title":"Woodpeckers Router Plane Straight Blade Only","description":"\u003cp\u003eThe Woodpeckers Router Plane Straight Blade Only is a genuine replacement cutter for the Woodpeckers Router Plane. Designed for general-purpose routing and levelling tasks, the straight blade is ideal for refining joinery, trimming the bottoms of grooves, housings and rebates, and bringing joint surfaces to a consistent depth.\u003c\/p\u003e\u003cp\u003eUsed with the Woodpeckers Router Plane's precision depth adjustment mechanism, the straight blade provides excellent control when removing fine shavings and making accurate fitting adjustments. It is the blade most commonly used for day-to-day router plane work, making it a useful spare for busy workshops or as a replacement for a worn cutter.\u003c\/p\u003e\u003cp\u003eThe blade features a lapped and polished back and requires only light honing before use. It is designed specifically for compatibility with the Woodpeckers Router Plane and works with the tool's secure double-wedge blade locking mechanism.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for cabinetmakers, furniture makers and hand-tool woodworkers carrying out precise joinery fitting and surface levelling operations. Supplied: One Woodpeckers Router Plane Straight Blade.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55174490980699,"sku":"114880","price":50.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114880_xl.jpg?v=1794566145","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-router-plane-straight-blade-only","provider":"Axminster Tools","version":"1.0","type":"link"}
