{"product_id":"woodpeckers-router-plane","title":"Woodpeckers Router Plane","description":"\u003cp\u003eThe Woodpeckers Router Plane is a precision hand tool designed for accurately levelling and fine-tuning grooves, housings, rebates and joinery. With excellent depth control and a highly configurable blade position, it makes it easy to remove small amounts of material when fitting and refining joints.\u003c\/p\u003e\u003cp\u003eThe large 88.9mm x 215.9mm (3-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 8-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) sole provides a stable reference against the workpiece. Three blade mounting positions, together with multiple blade orientations, provide excellent access into corners and allow the cutting direction to be adapted to the grain. A fine depth adjustment mechanism is designed to minimise backlash, giving precise control when taking fine cuts.\u003c\/p\u003e\u003cp\u003eThe base is machined from ductile iron with a low-friction, corrosion-resistant black nitride finish. Countersunk mounting holes allow shop-made fences to be attached, while the blade is held securely using a double-wedge locking mechanism. Two cutters are included: a square blade for general levelling and a spear-point blade for accessing more difficult corners. Both have lapped, polished backs and require only light honing to the bevel before first use.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for cabinetmakers, furniture makers and hand-tool woodworkers, the Woodpeckers Router Plane provides the fine control needed for adjusting joint surfaces, levelling the bottoms of grooves and housings, and refining rebates. Supplied with: Woodpeckers Router Plane, square blade and spear-point blade.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036529017179,"sku":"114857","price":329.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114857_xl.jpg?v=1793618596","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-router-plane","provider":"Axminster Tools","version":"1.0","type":"link"}
