The Woodpeckers Router Plane is a precision hand tool designed for accurately levelling and fine-tuning grooves, housings, rebates and joinery. With excellent depth control and a highly configurable blade position, it makes it easy to remove small amounts of material when fitting and refining joints.
The large 88.9mm x 215.9mm (3-1/2 x 8-1/2) sole provides a stable reference against the workpiece. Three blade mounting positions, together with multiple blade orientations, provide excellent access into corners and allow the cutting direction to be adapted to the grain. A fine depth adjustment mechanism is designed to minimise backlash, giving precise control when taking fine cuts.
The base is machined from ductile iron with a low-friction, corrosion-resistant black nitride finish. Countersunk mounting holes allow shop-made fences to be attached, while the blade is held securely using a double-wedge locking mechanism. Two cutters are included: a square blade for general levelling and a spear-point blade for accessing more difficult corners. Both have lapped, polished backs and require only light honing to the bevel before first use.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for cabinetmakers, furniture makers and hand-tool woodworkers, the Woodpeckers Router Plane provides the fine control needed for adjusting joint surfaces, levelling the bottoms of grooves and housings, and refining rebates. Supplied with: Woodpeckers Router Plane, square blade and spear-point blade.
Web Attribute Set Hand Planes
EAN Barcode 0810137208183
