The Woodpeckers Saw Gauge is a precision alignment tool for checking and setting the relationship between your table saw blade, mitre slot and rip fence. Correct alignment helps improve cutting accuracy and can reduce problems such as burning during rip cuts and inconsistent results when crosscutting.
Designed to travel smoothly along the mitre slot, the Saw Gauge uses three precision-ground steel pins to automatically adjust to different slot widths. It accommodates mitre slots from approximately 15.9mm (5/8
The gauge can be positioned to check blade alignment and then quickly reset to a different position for checking the rip fence. It can then return to the original position, making comparison measurements straightforward without recalibration. The dial indicator provides a clear reference for identifying small variations in alignment.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in the USA.
Ideal for setting up and maintaining a table saw, the Woodpeckers Saw Gauge provides a straightforward way to check blade and fence alignment against the mitre slot, helping you get the best from your saw and blades.
