{"product_id":"woodpeckers-sf-pro-universal-router-table-fence","title":"Woodpeckers Sf-Pro Universal Router Table Fence","description":"\u003cp\u003eThe Woodpeckers SF-PRO Universal Router Table Fence is a fully featured router table fence system designed to provide precise cutter positioning, micro-adjustment and broad router table compatibility. Its universal mounting system adapts to a wide range of commercial and shop-built router tables, while independent fence adjustments allow accurate setup for routing, edge profiling and jointing operations.\u003c\/p\u003e\u003cp\u003eThe fence features independent micro-adjustment of both the infeed and outfeed faces, together with a third micro-adjuster that moves the entire fence assembly. The fence rides on four ball bearings to provide smooth, accurate movement while maintaining alignment between the fence faces. Metric and imperial scales are provided, with clear indicators to aid setup and repeatability.\u003c\/p\u003e\u003cp\u003eThe universal mounting system accommodates fence track spacing from 425.5mm (16-3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 844.6mm (33-1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), making it suitable for many router tables, including edge-rail designs. A low-profile dust extraction port accepts either 63.5mm (2-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) dust extraction hose or 57.2mm (2-1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) shop vacuum hose to help capture chips and dust at source.\u003c\/p\u003e\u003cp\u003eThe fence is supplied with two sacrificial MDF fence faces and a pair of featherboard tracks. Compatible Woodpeckers Variable Pressure Featherboards and Super Track Flip Stops can be fitted when required, providing additional versatility for repetitive and specialised routing operations.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers looking for precise router table setup and easy adjustability, the SF-PRO Universal Router Table Fence offers accurate control and compatibility with a wide range of router table systems. Supplied with: Woodpeckers SF-PRO Universal Router Table Fence, two sacrificial MDF fence faces and two featherboard tracks.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036547858779,"sku":"114871","price":799.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114871_xl.jpg?v=1793618642","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-sf-pro-universal-router-table-fence","provider":"Axminster Tools","version":"1.0","type":"link"}
