{"product_id":"woodpeckers-sharpening-system","title":"Woodpeckers Sharpening System","description":"\u003cp\u003eThe Woodpeckers Sharpening System provides a precise and repeatable way to sharpen chisels and plane irons using bench stones. Designed to make sharpening easier and more consistent than working freehand, the system combines a stable two-roller honing guide with dedicated tools for accurately setting and checking sharpening angles.\u003c\/p\u003e\u003cp\u003eUnlike conventional single-roller guides, the Woodpeckers Sharpening Guide uses two rollers to provide stable support throughout the sharpening stroke. Precision-machined shoulders hold the blade square within the guide, while two roller positions accommodate different tool widths. The outer position suits blades from 3.2mm (1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 28.6mm (1-1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) wide, while the inner position accommodates wider chisels and plane irons.\u003c\/p\u003e\u003cp\u003eThe Sharpening Angle Fixture provides positive reference settings for primary bevel angles from 15° to 45° in 5° increments, together with a 2° micro-bevel offset for each setting. This makes it easy to reproduce the same sharpening angle when returning a tool to the stones. The separate Sharpening Angle Gauge provides quick references for checking common bevel angles before or after sharpening. Corrosion-resistant components make the guide suitable for use with waterstones as well as other suitable bench sharpening stones.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers, joiners and hand-tool woodworkers looking for consistently sharp chisels and plane irons, the Woodpeckers Sharpening System brings greater control and repeatability to bench stone sharpening. Supplied with: Woodpeckers Sharpening Guide, Sharpening Angle Fixture and Sharpening Angle Gauge.\u003c\/p\u003e","brand":"Woodpecker","offers":[{"title":"Default Title","offer_id":55036550087003,"sku":"114870","price":399.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114870_xl.jpg?v=1793618643","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-sharpening-system","provider":"Axminster Tools","version":"1.0","type":"link"}
