{"product_id":"woodpeckers-spline-jig","title":"Woodpeckers Spline Jig","description":"\u003cp\u003eThe Woodpeckers Spline Jig makes it easy to add strong, accurate splines to mitred joints using either a table saw or router table. Adding a spline increases the long-grain glue surface across a mitred corner for greater strength and stability, while also providing the option to create an attractive contrasting detail.\u003c\/p\u003e\u003cp\u003eDesigned for versatility, the jig uses two sections of Woodpeckers Super Track held square by powder-coated steel legs. Two height settings accommodate different projects, with the wider setting suitable for workpieces from 1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e (12.7mm) up to 16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e (406mm) wide. For projects wider than 16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e, the tracks can be repositioned to accommodate longer workpieces. Four flip stops make it easy to position and align spline cuts consistently.\u003c\/p\u003e\u003cp\u003eUHMW glide strips along the bottoms and edges of the legs reduce friction as the jig moves across the machine and help protect the table and fence from scratches. On a router table, straight cutters can be used to create different width spline slots, while a suitable dovetail cutter allows decorative dovetail-style splines to be produced. The Super Track also accepts the heads of 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e-20 hex bolts for attaching compatible hold-downs and accessories.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Its tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for box makers, furniture makers and woodworkers looking to strengthen and enhance mitred corners, the Woodpeckers Spline Jig offers a straightforward way to produce consistent spline joints on both the table saw and router table. Supplied with: Woodpeckers Spline Jig, four flip stops and four glide strips.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036550152539,"sku":"114852","price":204.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114852_xl.jpg?v=1793618495","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-spline-jig","provider":"Axminster Tools","version":"1.0","type":"link"}
