The Woodpeckers Spline Jig makes it easy to add strong, accurate splines to mitred joints using either a table saw or router table. Adding a spline increases the long-grain glue surface across a mitred corner for greater strength and stability, while also providing the option to create an attractive contrasting detail.
Designed for versatility, the jig uses two sections of Woodpeckers Super Track held square by powder-coated steel legs. Two height settings accommodate different projects, with the wider setting suitable for workpieces from 1/2
UHMW glide strips along the bottoms and edges of the legs reduce friction as the jig moves across the machine and help protect the table and fence from scratches. On a router table, straight cutters can be used to create different width spline slots, while a suitable dovetail cutter allows decorative dovetail-style splines to be produced. The Super Track also accepts the heads of 1/4
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Its tools are precision machined and carefully inspected in Ohio, USA.
Ideal for box makers, furniture makers and woodworkers looking to strengthen and enhance mitred corners, the Woodpeckers Spline Jig offers a straightforward way to produce consistent spline joints on both the table saw and router table. Supplied with: Woodpeckers Spline Jig, four flip stops and four glide strips.
