The Woodpeckers Stainless Steel Precision Woodworking Square with Rack-It is designed for accurate layout, machine setup and assembly checking. Combining a precision-machined stainless steel core with Woodpeckers' distinctive shoulder design and integrated scribing guides, it provides exceptional accuracy and ease of use in the workshop.
At the heart of the square is a one-piece stainless steel core, precision machined to establish the squareness of the tool rather than relying on pins, rivets or fasteners. The blade is heat treated and finished with a satin, non-glare surface, while laser-engraved scales are manufactured to a stated accuracy of ±0.1mm (±0.004
The cheeks are set back from the blade to create a shoulder that registers securely against the edge of a workpiece, allowing hands-free positioning during marking and inspection tasks. Integrated scribing guides spaced at regular intervals make it easy to mark lines parallel to an edge using a pencil, knife or other marking tool. The thin stainless steel blade also places the graduations closer to the workpiece, helping reduce parallax error when measuring and marking.
The squares are manufactured to a stated tolerance of ±0.0085° or better, making them suitable for precision woodworking, machinery setup and assembly verification.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers, joiners and woodworkers who require reliable, highly accurate squares for everyday workshop use. Available in sizes 150mm and 300mm.
