The Woodpeckers Square Rack-It Set brings together two precision woodworking squares for accurate checking, measuring, marking and layout work. The set includes 150mm and 300mm Stainless Steel Precision Squares, each supplied with its own wall-mountable Rack-It, giving you two versatile sizes that can be kept protected, visible and ready to use in the workshop.
At the heart of each square is Woodpeckers' one-piece, precision-machined stainless steel central core, rather than relying on pins, rivets or screws to establish squareness. Two cheeks form the beam, creating a shoulder that registers securely against the edge of your workpiece. The thin blade positions the scale close to the work for easier, accurate marking, while integrated scribing guides make it simple to mark lines parallel to an edge.
The stainless steel core is approximately 1.6mm (1/16) thick, heat-treated and tempered after machining, with a satin, non-glare finish that provides clear contrast with the laser-engraved scales. Woodpeckers guarantees the squares to be accurate to ±0.0085° or better, while the laser-engraved scales have a stated tolerance of ±0.004 total accumulated error. The wide base also provides stable support when checking components for square.
Woodpeckers is renowned for its precision woodworking tools, measuring equipment and workshop accessories. Its Stainless Steel Precision Squares are precision machined and carefully inspected at the company's facility in Ohio, USA, with particular attention given to accuracy, durability and repeatability.
Ideal for furniture makers, cabinetmakers, joiners and woodworkers carrying out demanding layout and assembly work, this set provides a choice of 150mm and 300mm squares for everything from smaller components to larger panels and cabinetry. Supplied as a four-part set comprising one 150mm Stainless Steel Square with Rack-It and one 300mm Stainless Steel Square with Rack-It.
Web Attribute Set Squares
