The Woodpeckers Stair Tread & Shelf Gauge provides a fast and accurate way to create templates for shelves, stair treads, risers and other fitted components where walls are rarely perfectly square. Rather than measuring angles and dimensions individually, the gauge captures the exact opening, allowing the shape to be transferred directly to the workpiece. Supplied with a Systainer for convenient storage and transport.
Two adjustable bevel ends pivot to match the angle of adjacent walls, while the modular beam system can be configured to suit a wide range of opening sizes. A sliding connector allows the gauge to be extended precisely into position, creating an accurate template without complicated measurements or calculations.
The system adjusts to create templates for openings from approximately 432mm (17
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for cabinet fitters, furniture makers, stair builders and woodworkers fitting shelves into existing structures, the Stair Tread & Shelf Gauge helps eliminate errors caused by out-of-square walls and awkward spaces. Supplied with: four 304.8mm (12
