The Woodpeckers SteadyCurve 2.0 Magnetic Bandsaw Template Guide helps produce accurate rough cuts for pattern-routed projects by guiding the workpiece at a controlled distance from the bandsaw blade. Used with a template attached to the workpiece, it allows components to be cut consistently oversize, leaving the ideal amount of material for final trimming with a router.
Operating in a similar way to the bearing on a flush trim cutter, the template follower maintains a set offset between the template and the bandsaw blade. This eliminates the need to follow a marked line freehand, making curved and contoured cuts faster, more accurate and more repeatable. The offset can be adjusted from almost zero up to 6.35mm (1/4
The updated magnetic base allows quick installation and removal using a single locking lever. Compatible with bandsaws featuring cast iron or steel tables and a minimum 305mm (12
Template followers are manufactured from a durable thermo-polymer material designed to avoid damage to the blade and can be replaced when worn. The guide works with commercially made or shop-made templates in MDF, plywood and plastic.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, chair makers, sign makers and woodworkers producing repeat curved components, the SteadyCurve 2.0 streamlines the transition from bandsaw cutting to final template routing. Supplied with: Woodpeckers SteadyCurve 2.0 Magnetic Bandsaw Template Guide, 3.2mm (1/8
