{"product_id":"woodpeckers-steadycurve-2-0-magnetic-bandsaw-template-guide","title":"Woodpeckers Steadycurve 2.0 Magnetic Bandsaw Template Guide","description":"\u003cp\u003eThe Woodpeckers SteadyCurve 2.0 Magnetic Bandsaw Template Guide helps produce accurate rough cuts for pattern-routed projects by guiding the workpiece at a controlled distance from the bandsaw blade. Used with a template attached to the workpiece, it allows components to be cut consistently oversize, leaving the ideal amount of material for final trimming with a router.\u003c\/p\u003e\u003cp\u003eOperating in a similar way to the bearing on a flush trim cutter, the template follower maintains a set offset between the template and the bandsaw blade. This eliminates the need to follow a marked line freehand, making curved and contoured cuts faster, more accurate and more repeatable. The offset can be adjusted from almost zero up to 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), depending on the amount of material required for final cleanup.\u003c\/p\u003e\u003cp\u003eThe updated magnetic base allows quick installation and removal using a single locking lever. Compatible with bandsaws featuring cast iron or steel tables and a minimum 305mm (12\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) throat capacity, the SteadyCurve 2.0 includes replaceable template followers for 3.2mm (1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) and 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) bandsaw blades. The follower adjusts vertically to accommodate material from 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 101.6mm (4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick.\u003c\/p\u003e\u003cp\u003eTemplate followers are manufactured from a durable thermo-polymer material designed to avoid damage to the blade and can be replaced when worn. The guide works with commercially made or shop-made templates in MDF, plywood and plastic.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, chair makers, sign makers and woodworkers producing repeat curved components, the SteadyCurve 2.0 streamlines the transition from bandsaw cutting to final template routing. Supplied with: Woodpeckers SteadyCurve 2.0 Magnetic Bandsaw Template Guide, 3.2mm (1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) template follower and 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) template follower.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036568928603,"sku":"114883","price":228.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114883_xl.jpg?v=1793618675","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-steadycurve-2-0-magnetic-bandsaw-template-guide","provider":"Axminster Tools","version":"1.0","type":"link"}
