The Woodpeckers StealthStop 4' Kit Combination Left provides accurate, repeatable length setting for mitre saw stations, workbenches and custom cutting setups. Designed around the Woodpeckers StealthStop system, it combines a micro-adjustable flip stop with Combo Track, allowing fast stop positioning and precise fine adjustment for repetitive cutting tasks.
The StealthStop slides smoothly within the track and locks securely in position. When not required, the stop folds completely into the track profile, then flips up instantly when needed. A brass micro-adjustment wheel provides precise positioning, making it easy to fine-tune cut lengths without repeatedly resetting the stop.
The Combo Track can be mounted vertically as a fence, recessed into a work surface, or incorporated into a combined fence and track system. This left-hand version uses a 1,219mm (4') track and includes a left-reading self-adhesive measuring tape. The stop system is designed for accurate, repeatable cutting and is suitable for mitre saw stations, chop saw benches and custom workshop fixtures.
The main components are manufactured from glass-reinforced polycarbonate, with corrosion-resistant internal parts and a brass micro-adjustment mechanism for smooth operation and long service life.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and workshop users looking for accurate repeat cutting and efficient stop control on a mitre saw station or bench setup. Supplied with: one 1,219mm Combo Track, two StealthStops, five mounting brackets, left-reading combination inch/metric measuring tape, 3.2mm hex key and mounting hardware.
Web Attribute Set Mitre Saw Accessories
EAN Barcode 0810018205058
