{"product_id":"woodpeckers-stealthstop-4-kit-combination-left","title":"Woodpeckers Stealthstop 4' Kit Combination Left","description":"\u003cp\u003eThe Woodpeckers StealthStop 4' Kit Combination Left provides accurate, repeatable length setting for mitre saw stations, workbenches and custom cutting setups. Designed around the Woodpeckers StealthStop system, it combines a micro-adjustable flip stop with Combo Track, allowing fast stop positioning and precise fine adjustment for repetitive cutting tasks.\u003c\/p\u003e\u003cp\u003eThe StealthStop slides smoothly within the track and locks securely in position. When not required, the stop folds completely into the track profile, then flips up instantly when needed. A brass micro-adjustment wheel provides precise positioning, making it easy to fine-tune cut lengths without repeatedly resetting the stop.\u003c\/p\u003e\u003cp\u003eThe Combo Track can be mounted vertically as a fence, recessed into a work surface, or incorporated into a combined fence and track system. This left-hand version uses a 1,219mm (4') track and includes a left-reading self-adhesive measuring tape. The stop system is designed for accurate, repeatable cutting and is suitable for mitre saw stations, chop saw benches and custom workshop fixtures.\u003c\/p\u003e\u003cp\u003eThe main components are manufactured from glass-reinforced polycarbonate, with corrosion-resistant internal parts and a brass micro-adjustment mechanism for smooth operation and long service life.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and workshop users looking for accurate repeat cutting and efficient stop control on a mitre saw station or bench setup. Supplied with: one 1,219mm Combo Track, two StealthStops, five mounting brackets, left-reading combination inch\/metric measuring tape, 3.2mm hex key and mounting hardware.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036569289051,"sku":"114855","price":269.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114855_xl.jpg?v=1793618596","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-stealthstop-4-kit-combination-left","provider":"Axminster Tools","version":"1.0","type":"link"}
