{"product_id":"woodpeckers-stealthstop-miter-sled-dropzone","title":"Woodpeckers Stealthstop Miter Sled \u0026 Dropzone","description":"\u003cp\u003eThe Woodpeckers StealthStop Mitre Sled \u0026amp; Drop Zone combines accurate crosscutting, repeatable length control and versatile angle adjustment in one precision-engineered table saw sled system. Designed as an alternative to shop-made sleds, it features a self-adjusting mitre bar, positive angle stops and Woodpeckers' proven StealthStop system for fast, consistent setup.\u003c\/p\u003e\u003cp\u003eThe sled is manufactured from 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) Baltic birch plywood with a low-friction laminate surface and attaches to the mitre bar via slotted fixings that allow adjustment from above the table. This enables the sled to be aligned to the saw blade without removing it from the saw. The four leaf springs in the mitre bar automatically compensate for wear and variation in mitre slot dimensions, helping ensure smooth operation with minimal play.\u003c\/p\u003e\u003cp\u003eThe fence provides 533mm (21\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) of workpiece support and extends to 737mm (29\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) when required. Positive angle stops are provided for 15°, 22.5°, 30°, 36°, 45° and 60°, making it easy to produce components for multi-sided projects. The micro-adjustable StealthStop retracts within the fence when not required and can be quickly deployed for accurate repeat cuts. The included Drop Zone provides a convenient support area for offcuts and completed workpieces.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers looking for accurate crosscuts, mitres and repeatable cuts, the StealthStop Mitre Sled \u0026amp; Drop Zone offers straightforward setup, reliable angle indexing and excellent workpiece support. Supplied with: Woodpeckers StealthStop Mitre Sled, Drop Zone, extendable fence, StealthStop, sacrificial end block, mitre bar, T-slot spacers and mounting hardware.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036570009947,"sku":"114896","price":299.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114896_xl.jpg?v=1793618676","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-stealthstop-miter-sled-dropzone","provider":"Axminster Tools","version":"1.0","type":"link"}
